RepoMan207
- Joined
- Jun 29, 2008
- 139
Re: 88' 7.4 Mercruiser Bravo Overheating
Jax,
definitely enough amps in the battery.
As far as getting the starter wet, I really flushed the heck out of it. I took the petcock housing out as well to get a better flow. I actually had the thought of "oh sh*t I got the starter wet" but then countered that thought with "well they did design them to get a little wet, even in the auto world".
I do see your point on wiring getting wet. In fact I have the "Thunderbolt Ignition System" in my boat and had it off the bracket when examining the risers and manifolds. Not sure what to do about that other then let it dry out a bit.
I did give it another try in the drive on muffs. It started after a quick grind. Of coarse it overheated again so I am on the war path of replacing the risers and manifolds against my better judgment (over $1000 in parts)
Once I get the risers and Mani's on I will replace the starter.
I had another thought on the starter issue. Occasionally I have an issue engaging into gear. on occasion it is quite difficult moving the throttle into forward gear initially. When it occurs I simply go neutral forward(correct term?) then back to stationary, then it goes into forward with ease. I also had an issue just after the whole overheating thing began of it not starting due to it (the ignition system / boat) thinking that the boat was in gear. I would move the throttle forward to reverse, then back to stationary and it would allow me to turn it over. Obviously this wouldn't be related to the overheating (I would think anyway) but it maybe playing a roll in the starter issue (maybe the gears might be engaging on the drive well the starter is engaged??? I hope not but if anyone has any insight, please speak up.
Jax,
