Put the fresh rebuilt carbs on today.
When I started I didn't see a pee steam.Does this motor have a pee stream?Should it be coming out the little black hole that the hose from the bottom of the engine connects to?
I took the hose off from the engine and could not blow thru it but sucked some water out. Is this a one way valve?
Could it be a thermostat issue?
It was sitting for like five years and I didn't check the impellor yet.I also didnt run it for more than like 1 minute at a time.
Thanks
Bryan
Thanks
Bryan
