I have a 1988 Johnson 9.9hp and recently did a head gasket and water pump replace. Now when running I get a very weak tell tale and it eventually overheats. Checked, impeller and key, no thermo, head gasket is good and tight to spec at 175 inch pounds, good compression, plenty of water out of the bottom but it's cold and there's not much water at the prop. The water out of the tell tale will scald your hand. My laser thermo gets temps over 230 at the bottom of the head after running at idle for 5 minutes. While open I cleaned and blew out everything including all water passage openings. The head was fairly clean with no major buildup. When I look at the water circulation diagram for a johnson 9.9 the water out of the tell tale looks like it should be cold and out of the prop it's hot. I don't get it? I took off the thermostat cover and ran the engine briefly to see if water would come out of the thermo housing and nothing, like no water is moving. Any body got any ideas?
