payton1803
- Joined
- Jun 15, 2013
- 15
88 bayliner 21' cuddy cabin 5.7 omc outdrive.......finally got drive off and was able to pull engine out of boat to acess what the condition of motor.....motor is junk 100% about the only thing i can salvage are the intake and carb, block and all pistons,cam and lifters are all junk. so here is my question I have a 350 engine out of a truck that i had, older small block, not one piece rear main seal, 4 bolt mains, 4bbl carb.......is this engine a good candidate for this boat, i know i will have to rebuild it, but should i use this engine or look for another engine that is the newer one piece rear main seal type (this is not a vortec) smallblock.. if i run the casting #s it says that my engine is a 69-79 truck 4-bolt main.
thanks any input will be appriciated
scott
scott
