Woodonglass
- Joined
- Dec 29, 2009
- 25,929
Absolutely nothing to be concerned about. Typical construction in many boats. I'd recommend putting back exactly like you found her
Ok, I'll have a look this afternoon to see how that would work.
When it's not under way, yes.
Have a look at the third photo in the very first post. That compartment with the hatch open has a drain with a hose down to the through hull in question. The through hull is below the waterline, except when boat os on plane. The drain it runs up to is well above the waterline... probably 12" at least. Plus, it's a watertight compartment, and its lip is another 6" above that. So the only risk is the hose giving out. I'll make sure I have good quality Trident hose for that, and marine hose clamps.
Sorry, I don't have any good photos from before it was all apart. Have a look in post #2 where you are looking towards the stern. There are two drains at the floor. Each of these has a hose going down to a scupper through hull. These are just below the waterline. The flappers have in fact failed long ago, and if I load it up enough and sit on the transom I can get the back end of the cockpit just below the waterline and some water to come into the cockpit.
I'm actually considering using regular 1.5" through hulls instead of flappers, and keeping a set of drainplugs on hand in case I ever had a need to plug them.
I don't understand, how can the hatch drain to an underwater fitting?! Nothing can drain to an underwater fitting without a mechanical/electrical aid to overcome the force of water. Is this the filling fitting and you just had a typo? If so, how you turn on and off the water to start filling. I did not see any valve on the bronze through hull!
Also, what makes you think that this compartment is water tight?! I did not see any gasket or lock on the hatch. I think you are refereeing to the fact that it doesnât leak as a container of water to the underside of the boat. Be that as it may, I was more concern about the situation of over filling and flooding the deck.
Leave it to Bayliner to do build things with whatever was Laying around the shop that day!!! Here's the deal, on boats under 20ft, it's not all that critical to be "Perfect". If it was, Bayliner would have been out of business a long time ago. You can put additional Bulkheads in if you want but they are not necessary IMHO.
Exactly. I have peeled woven roving off by hand quite easily but anything you do is going to be far, far above factory.
If I had to add anything, I would say that since your cap is an insert, your biggest challenge will be making sure it drops back into the boat at the exact same height so that the cap screws will line up perfectly. Parts grow, and points of references can get lost. Sometimes the thicknesses of the plywood and additional layers will be different. No shame in mid project cap reinstalls. I put the cap in and out 3 times on my Sport Craft build and glad I did. Cool boat!
The crew - that is us - is welcoming the addition of your daughter to the teamWelcome aboard, very impressive.
I noticed you mentioned "Epoxy"; maybe I missed it earlier in the thread but are you planning to use epoxy resin for this project?
Computer geek here as well and x-Microsofty
In this case, make sure you don't use 1708 or any fabric with CSM in it. There is a Bi axial 17oz for epoxy. You probably know that already but a reminder will not hurt.
1708 should not be used with epoxy resin, they are not compatible. It has an 0.08 layer of CSM in the back of it. CSM binder as dissolved by the styrene in the polyester resin. Epoxy has no styrene in it so the binder of the CSM will not dissolve. If you are going with epoxy resin, no CSM should be used.
