nphilbro
- Joined
- Dec 19, 2011
- 304
I haven't seen this one addressed yet. Hopefully some advice before I spend $40 on gas and launch for a failed lake test.
Last weekend I took my boat out for 3 days of fishing and used my kicker (this one) for trolling approx. 8 hours or so over the course of 2-3 days. Typically a 1 1/2-2 mph speed. I'm pushing a 19ft fiberglass boat - very normal stuff. The prop is 9 1/2x10 (stock).
On the 3rd day, about 4 hours in, I started to notice lack of speed for the rpms. I gave it throttle and the motor continued to operate very well, but seemed a bit on the warm/borderline hot side. There was plenty of exhaust through the hub but I didn't get any torque on the blade.
I immediately thought I spun the prop so I took it to the outboard shop today for a new one and he put it over a spindle in a vice and the prop was still solid on the hub.
Here's the caveat: I recently tore it down to replace one of those stupid plastic grommets at the power head because it was blocked. I put it all back to together and she ran great until this incident.
When I got home I checked all my bolts and realized I hadn't done the "break-in" check and the 6 base bolts were were all a bit loose (3/4 - 1 full turn loose). I didn't have any water coming into the motor but I had noticed a small amount of exhaust in the cowling throughout the the day. The tell-tale was normal. I checked the compression last night and still got the same reading as before the rebuild (can only get 70 since I have to pull start and hold the tool over the plug hole).
I just re-torqued these and and all other bolts back up and put it in the tank. It runs just fine, still, and idles right down to the very bottom end. I engaged the gear with the prop on and with a bit of throttle it acted like it wanted to empty the barrel with very good thrust.
Would those loose base bolts be the cause of loss of power at the prop? The performance of the motor gave no indication anything else was wrong outside of the prop thrust problem.
I'm ready to take it to the lake in the morning but would like some opinions before hand.
