88 Force 85 HP Water Pump
further
Hi All,
Can anyone recommend where I can order or obtain a water pump/impeller kit? I need to replace and this will be my first shot at it.
Thanks
maverick974
Re: 88 Force 85 HP Water Pump
Most any boat shop should have that. It's a popular item. I have a 1985 Force engine. 85 hp. Should be the same impeller if I'm not mistaken. Not expensive and fairly easy to replace. Just remember to make sure that the wings of the impeller are facing the correct way when you intall it. The boat shop should be able to steer you in the right direction.
A manual is helpful for anything you need to do on these engines.
Good luck.
MWBROWN
Iboats has them for a good price.
Try looking at sticky post number two. Step by step impeller change.
That will be a big help.
Good Luck
further
Thanks for the advice. Manual ordered and new water pump kit ordered as well.
