jerryjerry05
- Joined
- May 7, 2008
- 18,196
The Chinese ones are just cheaply made and they use inferior parts.
They mass produce and just hope that the crappy thing lasts long enough to outlast the warranty.
The original(pics???) if rebuilt right will last another 25-30 years.
The motor: any water intrusion will eventually kill it. Salt water especially.
The pump: if there is water intrusion it's not real bad unless all the oils gone.
The hyd.pump itself, there isn't really anything you can do to the pump part itself.
The seals in the lower part is what usually goes bad.
Depending on the age it can be difficult to take apart and repair.
Replacing the seal: disassembly can be tricky.
The parts can fly if your not careful.
You said earlier that the old one was working right??
You sure you want to open it up?
