88 HP Long Shaft Johnson Limited Edition Outboard Motor
patrick4266
I do not know the year but I have the chance to pick this up for a few hundred. Any one know much about this engine?
88 HP Long Shaft Johnson Limited Edition Outboard Motor with controls
tashasdaddy
Re: 88 HP Long Shaft Johnson Limited Edition Outboard Motor
88 is a good motor, but that depends on the history.
BUYING A USED MOTOR
overall condition, condition of the place you are buying it from, usually tells you how they care for things. compression 100 + psi, and within 10% of each other, good strong blue spark, no water in the lower unit oil. look for discolored paint, (sign of over heat at
one time, also scarred up bolts, as why. have them start it. if they fail to put it in a barrell or tank, or on muffs, or in the water, to start it they don't know what they are doing. best yet is to take it for a 30 min to 1 hour test run. also if remote controlled motor, the controls should come with it.
