88 Merc Reverse Issue
atm_73
I've got an 88' Mercury 25 with a tiller. The shifting cables are tied in with the throttle on this model. The engine runs great, and the forward gear engages fine, but it grinds when shifting into reverse. I have adjusted the linkage cables, but I haven't been able to get the thing to engage in reverse. Do you have any idea what this may be? Am I looking at new gears in the foot, or am I over-looking something?
If I have to take it to the shop, what cost am I looking at to have the foot rebuilt. Thanks in advance for your replies.
Barnacle_Bill
Re: 88 Merc Reverse Issue
Before jumping into the lu, I would get a manual and make sure the cables are adjusted properly.
atm_73
Thanks - I've got a service manual ordered. That will be my first route of attack is adjusting the cables out. Has anyone paid to have any lower unit work done? What cost will I be looking at if so?
atm_73
Ok, after getting the manual, and tinkering with the cables, I've found that the problem is most definitely the reverse gear and clutch. I've never pulled the prop-shaft on a lower unit, and need some help.:redface: Shop said it would be at least 700.00 for the fix, and I'm cheap!
I removed the prop, seal, and the "ring" with three screws in it around the "bearing carrier"? There is a black metal housing around the propshaft with three "tabs" or ears on it. There are two arrows on it - one points counter-clockwise, and says "on", and the other clock-wise and says "off". I made a tool to fit on the tabs, and tried to turn it both directions, to no avail.
Does this require heat? Or does it pull strait out? What am I missing here? Thanks again!
