88 Mercruiser Alfaone I/O Shifter/Throttle ???
Mokaman
Hello everyone (Not sure if this is the right forum). I have a 88 Mercruiser A1 with quicksilver controls. How do you know what cables to buy for replacements? Here on Iboats, I found this, http://www.iboats.com/Quicksilver_T...18665795--**********.398405274--view_id.22155
Are these the right cables? And if so, do I simply measure the old ones? Thanx for any advice in advance. The symptoms are, dies when shifting into reverse and no gear in reverse. Only in forward does it stay running and go into gear. Am I on the right track or am I all wet?
As a side note, I just replaced the outdrive and the test run all went well. Pulled her home no problems. Now I am trying to sell boat. and when someone wanted a test drive. She would not go into reverse. I was having a bit of trouble between gears lately as well. Like dieing between F&R. Very embarrassing at the docks with a local bass tournament starting up :redface:
