donwonnc
Thread starter- Joined
- Apr 18, 2013
- 19
Purchased this 88 Sunbird from first owners. 4.3 ltr V6 OMC Cobra drive. When putting into Forward slowly I began to notice one solid KLUNK noise or feel. If I powered up quickly, the KLUNK was limited to one or none. Called the sellers and they said that it had always done that one KLUNK. Took it to Marina, they verified that I had the recalled, replacement lower shift cable, red. They told me that they would try adjusting the shift cable. I got the boat back and the KLUNK noice/feel was gone for maybe a season and now has returned. No problems at high speeds. I am afraid to try to go slow and waiting to hear more than one KLUNK. Marina said run it till I need new lower unit gears. Along with this KLUNK, it is very hard to get out of forward gear like when docking, I have to yank the tar out of it, to go into neutral I will re check, but I don't recall any problems with the switch that briefly stalls the engine, to make shifting easier, ESA? I read the (stuart hastings??) report, about the recalls, the Dog that engages the forward gear is my suspect.
Also, I get 10-20 gallons of water in the boat and none is from wet swimmers coming aboard. Should I be taking on any water through this I/O drive? I have purchased a Bellows Kit, I have a Gimball bearing just incase. I have never removed any out drive, my specialty is Printing Presses. I have looked at building some kind of cradle to help me hold the drive as I do not want to get hurt. I imagine the bellows are real bad and I want to see the lower end of the shift cable, the bell crank area, clean it, maybe install a new cable, or do I. What would you guys do? Funds are tight. I have read OMC's reputation, so I apologize if I am asking a previously answered question. I do have an OMC service manual. I think I have a very good engine, thus my reason to give this boat a little TLC.
