88 Omc Seadrive gauge question
Robreefer
My tach seems to be messing up, and I'm not sure its telling me the proper rpm. The power tilt, water preasure, and GPH gauges never worked since I have owned the boat. I was wondering If it will be possible to replace the gauges with out changing any of the factory wiring? Or should I just try and get them from wellcraft? Also, if I can use aftermarket gauges, what do I need to look for when buying a new tach? Thank you In advance.
mikesea
Re: 88 Omc Seadrive gauge question
aftermarket tachs and guages are OK and offered for sale at IBOATS,wire diagrams will come with guage,the original wiring is fine to use.The advertisment for the guage/tach should disclose what engines they will work with
