IslanderVT
- Joined
- Mar 13, 2013
- 48
Getting started on replacing the gas tank, stringers, bulkheads, and deck in this boat. Its a fast hull design with a notched transom and pad keel, and has a great running Mercruiser 260 w/ Alpha drive, so its worth the trouble to get it back in shape.
Started with a cracked gas tank, which was caused by all the wood in the stringers and bulkheads around the tank being mostly rotted. This let the hull flex too much, which twisted and cracked the tank at one of the internal baffles.
Looks like this repair can be accomplished with a single sheet of plywood over the middle of the cockpit.
Original build was all plywood, and looks like an honest attempt at building a good boat. The key downfall was foaming the gas tank in place...this allowed water to sit around the tank and rotted every piece of wood in contact with it.
Rebuild will be mostly the same as factory, except no foam around the tank. Have neoprene strips I plan to glue to the hull to make stand-offs for the new tank.
Using marine plywood because the original build was done that way, and I think I can do the whole thing with 2 4x8 sheets, so cost isn't too bad.
Did not rip out the deck all the way to the hull...left an overhang enough to put in blocking under it to form cleats for the new deck to sit on.
Current status is about 1/2 done cutting out old stringers and grinding the old fiberglass from the hull. One more day on that and I should be ready to start on new wood and glass.
Couple questions:
- Original build had an air gap under all stringers and bulkheads (see pics on 2nd & 3rd post). Zero bedding that I could find. I plan to repeat this, just using PL at the ends of the stringers, and using peanut butter to form fillets (factory skipped this altogether). It is a light hull so I suspect they were worried about hard spots.
- Stringers are 1 1/2" wide, so I plan to laminate plywood with PL. Do most folks coat it with resin before laminating, or after it is one piece?
- Originally I thought this could be a simpler epoxy repair (I thought I just had delamination on the inside of the stringers), but after further ripout it needs all under-deck wood replaced. So I will be using Polyester. I had ordered some 17oz fabric w/o mat on it for expoy. I plan to use this up by covering the top and bottom of the deck with it. Does this sound OK...17oz fabric right on top of soaked plywood for protection? I'll order 1708 for the stringers and bulkheads. I've got some 10oz fabric for a finish veil that will cover the entire deck with one piece (60" wide). Flooring will be glued Vinyl (Londeck).
Here are some pictures:
Right after tank removal/cleanuo
Rotted wood in stringers and bulkheads:
Stringers rotted to powder...and this was marine plywood:
Couple questions:
