IslanderVT
- Joined
- Mar 13, 2013
- 48
Re: '88 Seebold 21' I/O Partial Restoration
Thanks for the Rustoleum advice Woodonglass....will roll on a waxed layer and also use the primer.
Those kind of T-Nuts are great....I'm using them for my front pedestal seats. Problem is I can't locate them with enough confidence for the rear bench seat without installing it...which I can't really do very well without sealing up the deck. The thread-in type can be installed in the finished deck, and also can be glued in with 5200 so they seal up better. Probably less pull-out strength, but its a bench seat so nowhere near the loads expected with a pedestal seat.
Trying to move to machine screws for everything, and thru-bolting where ever possible. I always find myself needing to go around and tighten up all the wood screws 2-3 times a season.
I'll probably just install everything with regular screws to get back in the water, and install these inserts next time I have it apart.
