88 special starter
surrender
1996 88 special runs great good ,even compression. new wirinf, battery and cables. When I go to start, I turn the key to start and engine will turn over and fire and ide. no big deal, if I advance the throttle and try it starts up. the problem happens when at times the starter will engage and turn motor over a couple of times then dis engage and then nothing. Turn key back to start and most times motor starts on second or third time with throttle advanced(in nuetral). I think the starter may be getting tired. I know with plugs out(when doing the timing or compression test) the started will turn motor over countinuosly if you let it. With plugs in it disingages after a couple of revs. never left me stranded and might be normal just seems kinda odd.
tashasdaddy
Re: 88 special starter
the starter bendix disengages the flywheel, when the flywheel turns faster than the starter. your engine is trying to start, but, is just on the edge.
100% normal.
surrender
Cool, thanks. Yeah, I though maybe I was alright. It has never let me down. or turned slowly.
