88 spl surging,dropping rpms,then surging.
73 Dolphin
Took the boat out today for the first time in a year. I do start in up regularly out of the water.
I don't have an RPM gauge but it will top out at about 42 mph.
I was doing a sedate 25mph and after 20 or 30 mins the RPMs started surging. RPMs increasing and dropping without me moving the throttle.
Probably dropping to <20mph then surging to 35mph or there abouts then repeating.
Yes its old fuel. I know they don't like that.
Pumping the ball made no different and the ball did not collapse.
I will check for water in the fuel, compression, carbs leaks, spark plugs etc.
Is there something else if should be looking at?
Thanks.
Honorary Supreme Mariner
Post the actual compression values here.----Test run with the cowling off and a timing light hooked up.----Test run one cylinder at a time.----Observe the flashing light.
Crosbyman
flush the old gas and run a small tank with some engine cleaner ...maybe you can clear up some obstruction... if not a carb job may be in order. jmho
airshot
Once you said running on year old fuel, you answered your own question !
