888, one click when trying to start
Markh762
Hi again, figured might as well be on a roll. <br /><br />Last night I replaced the ignition switch and slave solenoid in my 76 starcraft with 888 sterndrive to try and solve a starter problem. Turn key on, lights and guages flip on, turn to start and I get one click from the back of the boat, instrument lights go off but guages stay alive, no starter action. After the initial click I get no more clicks, action or anything until I disconnect the battery cables and then replace them. I only see one 40 amp break on top of the engine and it has 12v on either side before and after the click. I did just find Don S troubleshooting guide and will double check tonight but I've gone through most of the steps from my clymers manual already. <br /><br />Thanks, Mark
mkast
Re: 888, one click when trying to start
You didn't mention the other end of the battery cables?
Markh762
sorry, don't know exactly what you mean. Once I get the click I have to take the positive battery cable off the battery and then put it back on to reproduce the clicking sound. The click sounds circuit breaker like but I'm not seeing it. <br /><br />Thanks, <br /><br />Mark
searay3
Check the battery cables at both ends. Positive is on the starter solenoid, negative will attach to the block somewhere. Take them off and emery cloth the connector and contact surfaces to eliminate issues carrying hi-amps. (you could get 12v, but not carry current).
Haut Medoc
What they said....And what is the condition of the fat red/black wires themselves? Do they get hwarm/hot? I would check/clean all connections in the starter system, and see what that does first.....JK
Ayuh,............<br /><br />What They Said,...........<br /><br />It sounds like you Might be loosing the Ground.....
D
DJ
Guest
Check BOTH ends of your battery cables. Remove and clean BOTH ends of each.<br /><br />You have a connection problem.
trebor0301
Same thing happened to me.It was the negetive(black wire)cable.All the oily gunk got on the connection and I lost my ground.Took it apart lightly sanded until fresh bare metal and good as new.
Scaaty
Yep....check the ground (black/negitive) on BOTH ends
