88SPL gearbox shimming needed?
MAW31
while prepping the motor for a new season, I noticed the prop was touching the gearcase casting.
gearcase oil looked good. (new seals last year)
Thinking that perhaps the prop bushing had shifted somehow, I put on 2 other props but all props rub against the gearcase.
So...the propeller shaft assembly needs shimming?
Is this 'normal' or am I missing something.
Haffiman
Re: 88SPL gearbox shimming needed?
The hub is rubber, and it may happen from time to time it gets a bit 'off' after storage. Toque the prop nut to correct torque and it normally gets ok.
Faztbullet
Looks like your missing the thrust washer behind prop.....
MAW31
Thank you, Thank you, Thank you!
For as much as i had studied the gearcase assembly diagram, my eyes went right past the thrust bushing. (which had stuck to the 17P prop I had pulled off when I replaced it with my 15P to give the nephews/nieces rides yesterday).
Everything in me knew something was wrong, but I couldn't place it and even though I had some sad nephews yesterday when i cancelled rides, I'm soo glad i turned around and trailered it.
sooooo simple.
sooooo important!
cheers to every forum member! (kudos to you Faztbullet)
