89' 125 Force outboard head gasket
iwaterdave
Do many people put RTV on the head gasket? Mine came off with it all over it. Not real sure about marine engines... advice?
alldodge
Not an outboard guy but have never heard of using anything on any head gasket. Silicone would be tops on my list of what not to use. A head gaskets needs to seal high pressures and needs flat surfaces on the head and block, nothing else
pnwboat
+1 on what AllDodge says. Either whoever put the head gasket is unaware of the pressures involved, or they may have been trying to take an easy low cost approach to fix a problem.
jerryjerry05
No Title
IF????? the gasket doesn't seal because of corrosion it might be needed to help seal the cylinders.
The last 2 Yamahas I worked on the cylinders were not sealing with just a gasket.
I eventually used silicone cause the owners weren't gonna buy new blocks.
These were really bad corrosion riddled motors.
Both had NEVER been flushed after use.
So yes there can be silicone on a head gasket.
Not recommended but sometimes needed.
​The bottom where the exhaust chest mounts is corroded and had pin holes where the salt had eaten through.
More silicone.
