The 'up'worked, the 'down'quit. I got two new relays but they are tripping the re-set. So, I took off the tilt/trim motor cover for a look. The armature looks shiny new. No corrosion inside. Turning the armature by hand moves the engine up and down enough that you can see it. Brushes look ok. So far, everything's under control. But here's where I lose it. Putting the cover on the armature while it's out is easy, but the strong magnets of the field make it almost impossible to line the axle into the pump. Putting the armature in first and then trying to pull the brushes back to clear the commutator is proving frustrating. Is there an easier way of putting this together? <br />By the way, a relay is a relay, right? If it's 12V and the 5 blades line up? <br />A lot of rambling here but it might save some questions. Any help is certainly welcome. Thanks.<br />Bud
