reelistic2650
- Joined
- Aug 2, 2006
- 21
1989 - 15hp J15RCEC.
At the lake running about 75-80% WOT for 20 minutes. All of a sudden the motor drops to 25-30% and will not go any faster, regardless of tiller position. It will idle, start, and run fine at low RPMs. But after you hit that 30%, it will not go any faster. Here's what I've tried so far, with the same results after each step.
Removed carb, cleaned completely, and reinstalled.
Removed carb again, soaked metal overnight, and resinstalled.
New spark plugs - old and new were both are getting fire.
Motor will rev up in the bucket, but it takes it an additional second or two over the way it used to run. Lots of smoke, more than I remember from it running before.
One note about the timing: the throttle cam seems to have a lot of play in it. The (single) mark will not line up with the roller follower unless you push the cam clockwise.
Any ideas?
Any ideas?
