Re: 89 200hp rebuild
Like reeldutch said, you have to figure out what caused the engine failure or history is bound to repeat itself
. Posting some pics or emailing Dhadley with the pics would help. Usually by just looking at the piston and cylinder walls, one can get a decent idea what caused the failure, wheather it was a lean carb or an overheat, etc...<br /><br />You will be replacing the waterpump and tstats, as well as rebuilding the carbs and fuel pump, so you will be able to see if the carbs are gummed up or if the impeller was shreaded.<br /><br />It would be great if you could post some pics of your progress along the way. I know I and others would love to see an engine rebuild and in fact I wish people did it more often. You can upload your pics a www.photobucket.com and then post the links here. If you are interested I could walk you throught the process of posting pics.<br /><br />Good Luck
