Volphin
Thread starter- Joined
- Jun 5, 2011
- 1,405
Hi guys,
I was finishing up my repower and have run into a funny problem. According to service manual 7, on page 4E-4 (attached) distributor should be wired this way:
White/Red to Dist from Module: OK
White/Grn to Dist from Module: OK
White/Grn from Dist to Shift Inter. Terminal block opposite Gray.
Normally not a problem. Except I have TWO White/Greens coming out of the harness.
I attached one to the dist with the other from the module. Does the other go to the Shift Inter block?
Why would they run it through the harness instead of the more simplistic wiring explained in the diagram?
Does it matter which is attached to the dist?
Thanks everyone!
Thanks everyone!
