sptjet90Reflexx
Thread starter- Joined
- May 28, 2011
- 383
Got the new Michigan motors EST system installed and my boat started right up. (she died on me in the water and got fed up with fooling around with the no spark issues).
For timing the guide says -4 BASE TIMING after she is warmed up with the base timing dongle hooked up to the + and distributor. When I unplug it is it suppose to go to 0 or what? these instructions are not very informative.
Also it does not seam like the motor shifts any different with or without the shift interrupt hooked up. I checked the switch and it does idle down the motor for a split second so I know its working but it does not make a difference if its hooked up or not.
