Bought a boat with an 80 hp 89 merc. Said they ran it last year.... ran a cold compression test at 85 90 90. Got it home and it started right up. Seemed a little rough but I'm used to my 6 cylinder 135. Fogged for a bit with seafoam. Then tested compression. 85 95 95. Top cylinder weak. Pulled plug wire at fast idle and it didn't make much difference on that plug. It did on the other two. I just got done completely decarbing it with seafoam and sprayed a bunch in the cylinder. Im planning on letting it soak over night and checking it. Wonder if my carb needs cleaned on that cylinder?? Getting spark. Just not firing as well. starts right up. Thought weak compression would be hard to start. Any thoughts?
