Re: 89 90hp Rude missing on one cylynder
Lesse if I can shed some light here.
The fuel pump is run on pulses from the engine (#4 cylinder specifically). The pulses move diaphragms inside the pump. Those diaphragms are tensioned by springs etc. Anyway, the pulse line is only supposed to contain air from the engine. If a tear in one of the diaphragms internal to the fuel pump develops, the fuel pump can leak fuel straight into the #4 cylinder bypassing the carburetor and all that. This creates a rich condition in #4. If the fuel pump has a tear in a diaphragm it can often be detected by the bulb not staying hard (fuel is leaking out after all). You'll only find the bad diaphragm by taking apart the fuel pump. Visual inspection of the assembled pump won't spot it at all.
Alternately, if there is an air leak in the pulse line, air can get sucked into the #4 cylinder. This can create a lean condition in #4.
Either one of these could be causing a problem. However, the rich condition is more likely to cause the cylinder to not fire at all. The lean condition would probably cause it to run hot, and sputter.
