89 Bass Tracker Pro17 Console Switch Layout
kofkorn
Hi all,
This weekend I purchased an 89 Bass Tracker Pro17. The prior owner replaced the decking and carpet this spring time. Unfortunately he was not really adept at wiring, and decided to do the least possible to get back on the water. To that end, most of the switches weren't hooked up or were hooked up incorrectly.
I'm chasing wires down and trying to put everything back as best as possible. However, I have run into a little pickle, as all of the printed labels that detail what each switch is and what it does are completely faded away.
1) Based on what I CAN see, the left switch is the navigation lights, with up being Nav, down being Anchor, and center off.
2) It seems that switch #2 is interior lighting???
3) Switch #3 is impossible to read, but I'm guessing it should be the bilge pump?
4) Switch #4 would appear to be the livewell pump with down being manual and up being auto (on the timer)
Can anyone please confirm/correct the labeling above?
Additionally, the sensitivity switch that attaches to the flasher / sounder is still there, but the two wire lead was cut. The two wires were red and black, which would usually indicate +12V and Ground. Is that correct?
I've got to go through and clean all of the contacts on the fuse panel, as I am getting fluctuating voltages based on very small load changes.
I've attached an image below. Any help is appreciated.
Thanks!
rageman
Re: 89 Bass Tracker Pro17 Console Switch Layout
You can call tracker and get them to e-mail you a wiring diagram for your boat.Thats what I did,I have a 97 pro 18 went thru the same stuff with my wiring.
kofkorn
Thanks, I actually did that yesterday afternoon after reading other posts on various forums. I was pleasantly surprised to receive the wiring diagrams in my email about 20 min later.
I was able to trace things around and hook everything back into it's original place last night. After a little wire brushing of the fuse contacts, I was able to get everything running except the flasher/sounder.
Thanks for the info!
