89 Evinrude 115 o/b
Jeff paitsel
I have a 89 115hp evinrude. It starts fine and runs fine without a load on, but in water it has no power and won't get above 10mph. Do I have a lower end problem or something else
HighTrim
Re: 89 Evinrude 115 o/b
Welcome to iboats.
I would start with the basics, spark and compression.
Post what you find, if you need help with these tests let us know.
Not likely a lower unit issue, short of possibly the hub in the prop being spun, in which case it would over rev when you advance the throttle, giving you no power.
Jeff paitsel
Thankes. I changed plugs first and gaped then at .035 will check compression next. Will lt you know.
HighTrim
What did the plugs look like when you had them out?
While the plugs are out checking compression put a spark tester on the leads as well to ensure that you are getting spark to all cylinders.
HighTrim
BTW....you should have Champion QL77JC4s in there gapped to .030
Jeff paitsel
The plugs were wet and black. The plug is right but will reset the gap thanks
Jeff paitsel
Checked plugs, clean but wet. conpression running 115,110,115,110,1 through 4. I regaped plugs to.030. whats next? Anything will help.
Have good spark on all
HighTrim
Is it over revving but not accellerating? Have you checked the hub for your prop for being spun?
Does hitting the primer pick it up? Spraying pre mixed fuel in the carb throat? Pumping the fuel primer bulb?
Boats not water logged or you're not draggin the trailer from the eyehole through the mud are you!? LOL :)
Jeff paitsel
No its not over revving. I was running back in at about 3500rpm after fishing all day and it just lost all it's power. Rpms droped to 2000 and speed to 10mph. If I run it in the shop it runs great, starts fine,idles at 250/300,powers up great but under load it just won't go.
