wutevvvver
Thread starter- Joined
- Apr 3, 2012
- 29
200 xp STLCEB200 1989 E-rude. Went to the lake this morning cranked up the motor and putted around the lake at about 2500-3000 RPM (new gearbox). While there I stopped and restarted motor several times. No problems. My last start was fine but motor was lugging while trying to accelerate, so I moped to the marina area and figured I'd fish a while. About an hour later I put the boat on the trailer with trolling motor. My bat gauge showed 11 volts and motor wouldn't even crank. I figured to low voltage. So after I get boat on trailer and am preparing to leave I smell a plastic burning smell and see a little smove coming out of vent on motor cover. I quickly disconnected battery and then removed motor cover and see a tiny amount of smoke that appeared to be coming from the power pack. After getting home I inspected the power pack outside and inside to see what melted. Nothing appears to be burnt but the rubber sealant around the wires in the power pack cover looked cracked and split.
So I guess my question is, what the heck happened? Is there a procedure for testing the power pack for shorting? My manual tells me how to check power pack while connected to battery but I am not going connect it until I get an idea of what's wrong.
I do have a trim switch that sticks occaisionally, could that be the culprit? I'm lost
