I have an 1989 evinrude 70hp, mechanic said VRO is failing on the fuel side of the pump. Said it is pumping oil fine. Any suggestions? Also indicated middle cylindar has got low compression, now I just had a problem with water in the gas, could water have gotten in the rings and siezed it up, is it worth spraying PB blaster in the cylindar or any other hocus pocus to see if I can get the compression up for 90PSI?
