'89 evinrude 9.9/15 hp carb bogs at full throttle
bassman32
Need help my motor bogs at full throttle, but if I squeeze the prime bulb the motor smooths out and runs fine. Is this a dirty carb,bad fuel pump or what?:confused:
kbait
Re: '89 evinrude 9.9/15 hp carb bogs at full throttle
Symtoms of a bad fuel pump, but FIRST, confirm every fuel hose connection from tank to carb is leak-free, and confirm tank screen isn't plugged/restricted. Also, remove filter cap on fuel pump and check screen.
Rick.
Agree with above. Could be your tank is not vented? Weak fuel pump if nothing mentioned works. Best of luck. Rick.
