Re: 89' force 125 rpm cutdown after warming up
Shark Fisher,<br />First I would recommend you pick yourself a repair manual. Most good boat dealers will have them. I would bet that place (they sell Prolines and some other makes) on 95 as soon as you exit 144; or that place on Abercorn (near Savannah Mall) would have one.<br /><br />If you do find blockage and the spray is still weak You may want to change the impeller. It isnt really that hard on the Force. Dont be fooled if the impeller looks okay (it has all of its paddles) as the paddles may be weak - which would be the cause of the weak spray out of your pee holes.<br /><br />As for decarbing. The most popular form is a spray that you spray into the carbs. I use it once per year. In addition I also run Quick Kleen once per month in the summer (this comes in a bottle and you mix it an ounce per 6 gallons of gas). Between these two actions I keep the ole Force running pretty clean. Would recommend you do this also. Force motors are older tech but do carb up as they dont burn as clean (although that is debateable) and the newer motors. If the motor hasnt been decarbed dont be surprised if it smookes like a tar kettle. <br /><br />As far as the stator test. Im not familiar with a test you can do. Maybe some of the smart guys can point you in the right path. I had to replace one last year as a result of intermittent electrical problems. One minute it would run great - and would run like that for an hour. Then go back out and it ran like s--t. It would cut out bog down, pick back up, stall down, miss......and then as I would threaten to take it out of the water....it would behave. An hour later (or the next time we went out) it would run great. It drove me nuts.<br /><br />Best of luck to you<br />Deerdog<br /><br />Bryan,<br />Looks like the water is back up in Falls Lake now. It looked very low this winter as did Kerr. Kerr is a blast. I pretty much grew up on the lake. I guess the biggest problem up there now are the asshole jet skiers - well the ones with no sense as not all of them are assholes. They did start cracking down on them last year though and hope it will continue.<br /><br />Deerdog
