89 Force 125 Tilt/Trim Relay # ??
SmurfOnAScarab
Well as many of you, Ive recently come across a failed relay in the Tilt/Trim wiring.
Up works, down doest. I switch the relays, down works up doesnt.
I go to the autoparts store and get the closest matching relay I can find, nothing works at all. So I am assuming there is a special relay I need.
Does anyone have a part number, or can point me in a direction for the correct relay?
Thanks
My current relays are Bosch 0 332 204 157 12V 20/30A
RRitt
Re: 89 Force 125 Tilt/Trim Relay # ??
it is a standard "Single Pole Double Throw" relay. Usually referred to as SPDT.
mreinsmith
P/N - 803632T or 87-F660917
do a product search for "803632T" here on iboats and you'll find it.
Their search system is a little odd, once you click "details" you'll get a list of parts, you will find the "803632T" in that list.
M
