AGrayEngineering
Thread starter- Joined
- Jun 3, 2009
- 20
I know its long but it gives the whole story :
Background: I bought the boat in Feb of 2009, replaced plugs, new gas and it has run fire for 50 hours and though I hate to admit it last weekend I ran the boat out of gas.
Then yesterday with 2 full tanks I take it out for an afternoon of wakeboarding with some friends, I back her into the water, fire up the motor pick them up at the dock and we?re off, after a few runs wakeboarding I hear the motor sputtering in the midrange with an obvious power loss. I swim back to the boat and try it myself. Low range is fine, midrange it misses and sputters and once it gets to high range its fine. So as I work my way back to the dock I try a few things to start to diagnos the problem, pumping primer bulb doesn?t do anything so I don?t think its lack of fuel due to a fuel pump issue. Swapping to gas can 2 helped a little but not enough to cure the problem completely. At the boat ramp I pulled the fuel filter screen ? completely clean, I pull the carb off check the bowl ? completely clean. I reassembled it and tried again, this time it?s defiantly better then before with very little missing but still something isn?t adding up. Good enough to keep going we wakeboard for another hour or so with almost no issues at all, after running the gas can 2 down I switch back to gas can 1 and again some sputtering occurs.
My first instinct is that I picked up some junk when I ran it out of gas and its blocking one of the jets, though if this were the case it should have still been a problem with the second gas can. Next I?d blame the gas itself, but I got both cans filled on the same day so the gas should be the same.
I don?t really know where to go from here, my plan for this afternoon is to take the carb off, and clean out all the passageways, clean the fuel pump and fuel system back to the tank, empty both tanks and get new gas.
Let me know what you think, we had a day on the lake planed for tomorrow so hopefully I can fix it tonight.
Thank You
Thank You
