I finished my carb rebuilds and installed a new water pump.
So I prepared to dive into my VRO removal and install a new fuel pump. I ran into a few gliches in my thought process, so a few questions are in order.
1. I located the 3 bolt holes to mount to fuel pump. Can you tell me what the bolt sizes are, so that I can tap them as they have paint in them.
2. What do I do with the other fuel lines that are coming off the VRO fuel pump?
a. two fuel lines come off the fuel fitting from the VRO, one goes to the carb and the other goes to the solenoid with the red lever. Two smaller lines come off the solenoid and go back to the carbs.
I assume the the fuel fitting that has all these hoses will be rerouted to the new fuel pump?
3. Do I plug the oil line from the VRO to the fitting that goes into the powerhead?
I think I have all this figured out, but I just want to be sure I am not missing anything before I attempt to start this motor.
Thanks a million everyone,
Caddis295
Caddis295
