89 Johnson 90 HP, keep blowing fuse after cranking
GSX455
OK, when I can get the starter to turn over, if it sits and I try it again the fuse is blown. After 5 fuses, what cause a 20A fuse to blow repeatedly?
Bad solenoid? bad wiring, ground connections were checked by the starter and they are tight.
F_R
Excessive current is what blows fuses, usually some sort of short to ground. We have no way of isolating it from a distance. Of your suggestions, "bad wiring" might apply. "Bad solenoid" would be so rare as to be completely ignored.
Check the engine and boat wiring harnesses. Look for melted wires or places where insulation was rubbed off.
jakedaawg
Get a 20A circuit breaker, wire it in place of fuse...that will save some $ and pains in the neck as you trouble shoot.
look first where harness enters at cowl, lots of movement there. Is it pinched? Peel back the black cover and look for bad wire.
You can also disconnect at the big red plug. Then use a remote start switch. If fuse still blows you are looking at something on the motor side, if it doesn't you are looking at the boat side.
Does operation of the trim switch seem to make it blow? If the TNT switch is on the throttle look at base of throttle handle.
Although Because you state "when I can get it to turn over" I would concentrate on the yellow wire with red stripe and the red wire, both run through the harness.
My 1st guess would still be in the area where it goes into the cowl. 2nd guess would be where harness goes in to boat at the motor well. It doesn't have to be a bare spot with a short. A severely pinched wire can do it also. The pinch increases resistance.
