alumacraft 170
Thread starter- Joined
- Sep 20, 2024
- 4
89' johnson 90hp vro usually doesnt charge. Connections are clean and tight. I tested voltage at idle at the juncton block where the voltage regulator connects to and i get 12.6v. Ive replaced the regulator and today the stator. The flywheel looks fine, no cracks or broken magnets. I used an oem regulator but a cheap caltric stator. The new stator tests .4 ohms and puts out 2v ac. Any ideas? Also do boats normally charge at idle or only higher rpms?
