Firefox11
- Joined
- Oct 22, 2010
- 18
I have been reading some posts looking for an answer to the problem that I am having, and I'm hoping for some good advice to resolve the problem. I purchased the boat with this problem and have had it working one time for a couple of days then it went back to the same issue.
The motor will start and run great at idle. It will even Rev snappy to 3k RPM, but once u try to pass 3k RPM it will start to surge as if the motor is starving for fuel. It is also smoking a little excessive, but I'm sure thats probably due to the fact the original owner use to drive the boat around no more than 3k just to use the boat since it wouldn't accelerate. When I had it working for two days, I removed the fuel pump and cleaned it. There is a one way flapper valve built into the plastic housing that never seemed to get clear. I put the pump back together and the motor would rev to 4,500 (I wouldn't want to rev anymore out of the lake other than very short burst). This worked two days, then the problem started happening just when I was going to take it to the lake to test it. I took the pump back apart and found the one way flapper valve hard to blow air through one minute and easy to blow air through the next. I wanted to purchase another side housing but I couldn't find a replacement part so I bought another VRO2 pump to be sure. After resolving the carbs overflowing due to fuel pressure, the motor will start very quickly and idle very smooth and even rev smoothly at 3k RPM. The problem is going past that. I have cleaned the carbs, replaced the tiny vaccuum lines with the same, replaced all the fuel line, replaced the primer bulb (Which gets hard), and gapped all the plugs. I DID notice some electronic goo under the flywheel. Would a Bad Stator cause this sort of problem to happen? I can see that the Timer Base assembly has been replaced with a new one, but the stator looks to be the cause for the leaking goo. I have not checked for charging as of yet. I was starting to think the top seals could be causing a lack of gas in the top two cylinders possibly causing a surge?? I checked the plugs, and they are black with carbon deposits, esp since it is smoking a bit. Would the seals cause this?? The Goo from under the flywheel, or is there a fuel problem that could cause this?? Please assist, I would very much appreciate some professional opinions.
Just some general information, I get 90 on all cylinders except port side top cylinder, and it gets 80psi. I use to do outboard repairs on older outboards with my dad, but never worked on this year model Johnson before. I have done extensive mechanical work as well as carpentry work. I'm good with my hands. Any information would be appreciated.
Thank you very much..
Brent..
Brent..
