I just acquired an 89 Mariner 135 with a few issues. I just finished replacing the fuel line and primer bulb and the fuel line to the gas tank. I have a bulb that still stays shishy and goes limp after running for a few minutes. I just noticed today that if I prime and prime and prime that gas comes out the prop exhaust. COuld this be my fuel pump? The symptoms I have is that the engine has low power, starts OK but is impossible to start after it has run for a bit. I generally does not idle well and will stall after it warms up. Could it be my fuel pump causing all the problems?
