springer_97011
Thread starter- Joined
- Sep 11, 2001
- 4
Im having a problem with the temp sensor alarm going off.I have replaced the water pump,checked for debrie inside the exhaust plate, and pulled the thermostat by the bypass valve.A bench test showed the sensor sloses at 185 degrees.The water coming out of the tell tale is cool and the engine feels only warm.Has anybody had a problem loke this or ideas what could cause this?Any tests to check temp of engine or componets would be appriciated.Also this motor has a pump on it.
