First the following link contains historical details related to what I 've done on this motor:
http://forums.iboats.com/showthread.php?t=415480&highlight=air+fuel+filter
I now have it running on the water but when I go to WOT it planes out then startes to loose RPMs. If I pump the ball again and get fuel into the filter it will again start to plane out then loose RPMs again. My guess is that I have an air leak between the tank and pump. Everything is new from tank to carbs and I've rebuilt the fuel pump. Carbs have been rebuilt and everything is new except the floats which seemed fine.
I'm going to get a new bulb, new fitting at the motor and use a new tank that I have but wanted to get input while that stuff comes in. Does this sound like an air leak? I'm still in the process of adjusting everything and it currently only gets to about 4000 rpms at WOT. I run out of throttle travel so I have a feeling that needs to be adjusted. Right now the carbs are sitting at 1.5 out. I can't seem to get the knack of adjusting them but will give it another try once I have this fuel delivery issue resolved. Where they sit doesn't seem to have any hesitation on a hole shot.
I'm making progress and learning on the way. The person I got this from was having problems with air in the lines from the oil injector. I don't have that on there now and I'm thinking they monkey'd around with the settings before they figured out there was an air leak.
