lunacyfringe129
Thread starter- Joined
- Aug 10, 2005
- 8
hey guys...im new to the forum. I am a proud owner of a 1989 merc black max 150. Its a great engine, but yesterday I was out cruising and the engine was running great, until it decided to die on me out in the middle of the lake at around 3500rpm. I was just cruising around the lake, not even working the engine hard. It sputtered and stalled out, and when I tried to start it again, the starter wasnt able to crank it over, almost like the pistons had seized.It had cooling water and oil, and the block wasn't hot, so I knew it hadn't overheated. But what got me was when I tried to start it 5 mins after. It started right up, but was missing really bad. I was just happy to have it running again, and it got me back to the dock. The entire way back it was missing really bad, but was able to keep the boat up on plane. I don't really know where to start on this diagnosis. I checked the plugs, and they are all fine, and the engine once again starts and runs perfect. Some guys are telling me that there could be short in the ignition somewhere, but why would that cause the engine to not crank over for 5 mins? If you guys could give me some insight on where to look, or even just some info on if this has happened to you before, I'd really appreciate it.
Thanks, Tyler
Thanks, Tyler
