89 merc v8 305cid 190 temp again...ugh...
nickcasa
ok here we go again, before i begin, thanks to everyone's advice...heres my store...
new alpha1 outdrive, 35 hours on it (SE106)
new impeller
new circulation pump
new tstat housing
new tstat
new hoses
new manifolds and risers
tstat housing is clean as is tstat
new spark plugs, coil,distributor cap,rotor
new temp gauge
after changing the manifolds and risers temp came down from 200 to 190 (they were rotted out), just went out today in palm beach,fl, water in the ocean was about 88....i now have a good amount of water coming out of the tell tale where i wasnt before, and i trust the gauge...felt the engine while running and it is a bit hot....any other ideas i should check? i really wanna get it down to 180,175.....im gonna get an IR gun just be sure but what else can i check....the temp never goes past 190 and i ran for 4 hours today....don s - thanks for your previous advice of the manifolds and risers, they were really nasty!
Nick
jerryjerry05
Re: 89 merc v8 305cid 190 temp again...ugh...
If memory serves: your temp should be 160 With everthing new and no blockages in the hoses(impeller pieces) Maybe the guage is off. Jerry
nickcasa
well theres no blockages i can see in the hoses, housing or risers, where else should i check? is it possible the block is clogged or something? i'm not sure where the water flows inside the engine.
Ayuh,.... About the only thing I don't see mentioned is the P/Steering Cooler......
nickcasa
could you please educate me as to where / what that is??? never heard of one, although i did flush the power steering fluid, but all of that was done on the pump end.
Ayuh,....
It's usually mounted in the in-coming water line between the outdrive,+ the T-Stat housing....
Gary H NC
All it takes is one little piece of rubber from an old impeller to plug the PS cooler up.Or it could be heavily corroded inside.
chiefalen
Bingo bond-o. Ha i'm a poet also.
My 2 cents, you have a flapper get loose. Plugged up the exhaust.
nickcasa
when i replaced the risers i checked the flappers, they're in there, thank god, would anyone have an engine diagram showing what this part looks like??
fishmen111
I saw temperature gauge, but no sending unit on your list?
nickcasa
sorry, both senders (brass things) were replaced with the new tstat housing, i'm going for the p/s cooler, only thing left....
