Hi -<br />I have a 89 3.0 mercuiser. Start great, runs perfect for 1/2 hour or so then starts to bog under load. Will idle OK but need to limp in. If I turn it off it will not start again. After a cool down period (1/2 hour) It will be OK again. Temp gauge always reads about 150 deg.<br /><br />Have replaced the following - carb, points (replaced with electronic module), plugs, wires, coil, dist cap. Adjusted the timing.<br /><br />HELP!<br />Thanks..
