Re: 89 olds cutlass supreme update
I would get the electrical drawings and start checking the wires. Or go to the auto wreckers and get a new injector harness and try it. If you have a pick your part there that might be a cheap way to go. Grab a crank sensor while you are there.
When you say the "injector harness" what do you mean? You saw that I had the injectors replaced, so do you mean the connectors that connect to the fuel injectors? Im going to replace the fuel pump even though I know that is not the problem because it is in that one bank of the fuel injectors. The underbody is pretty rusty so I don't know if that would cause a problem with a ground or not. I have the Haynes manual for the car and it has some electrical drawings in there that I might be able to trace. THANKS SO MUCH!!!!!!!!!!!!!
Also, dolluper, how do I check this crank sensor? I see its location is, Under hood, center, rear engine area, passenger side of exhaust pipe, above oil pan, mounted in engine block. So how do I check it and what do I need to be looking for? Also why would this be the problem? Im not doubting you at all Im just looking for some knowledge of this sensor. THANKS TO YOU AS WELL!!
