nitrokev85
Thread starter- Joined
- Mar 14, 2009
- 6
I have a 1989 baretta, 18' IO. with a 130hp OMC motor that will turn over and spark fine, but will not run.
replaced parts: coil, points, condensor. compression is ok, timing is good
I have dismantled and cleaned the carb. spark is fine
It is so close to firing up, but something is causing a problem, once it started firing over on its own, about 4 rotations but it was very slow, then died.
thankyou for your help.
Kevin
Kevin
