Runs fine at 1st but then starts to bog down(stall/jerk)at WOT(slows to about 2-3000 rpms)."Feels" like fuel restriction. Swapped fuel line,tank vents ok,bulb firm,filter clean.In nuetral/throttle up higher rpms ok,only looses it when under way. Also when it starts to stall,I CAN DEPRESS THE KEY CHOKE and it will pick right back up(cause it gets the gas?)1st tank of gas after layup & treated with double mix of Seafoam. Maybe mix knocked something loose thats now stuck in carb. Rulimg out(?)powerpack/plugs,electric because takes off when it gets the key choked? Fuel pump would have to working too I assume? Need some more trouble shoot recommends to narrow my track.Should I use "Deep Creep" type into carbs?
