Do you know what size compression tester I would need? 14mm or 18mm? And if it is compression does this mean new rings, rebore or what? Thanks!Does the choke help it idle? If yes the start by cleaning the carburetor. If no then start with a compression test.
Yes. Likely the case.You likely need to clean the carburetor GOOD. Like soak it overnight. There are passages that feed all the low speed circuits and different ones that feed the high speed circuits and it's likely you have some blockage in the low speed circuits. I had a very similar problem and tried the clean the carb several times with spray and a 4 hour soak. No difference. Let it soak overnight and the problem was gone.
with motor ON spray some soapy water with a small spray bottle behind the carb and the beginning of the reed valve assy and check if with bubbles.
You must disassemble the carb before soaking. After, blow out all passages.Sorry to confound all the experts...the carburetor soaked overnight in OMC cleaning fluid still won't run unless rpms are 4,000+. As a note soaking the o-ring around the high rpm jet screw made it balloon and it had to be replaced - luckily still had the old 8hp carburetor (believe I bought the 9.8hp with electric choke from Paul a couple years back) and salvaged the o-ring from it. However, no improvement. Also swapped the old 8hp carb in and still the same problem. If the choke is held open the motor will run ok at 3,000 or less rpms. Seems there is an air leak somewhere preventing the jets from providing enough fuel at low rpms. I even swapped in the old fuel pump without effect. Adapter for the compression tester should arrive shortly and I'll run that. Any other thoughts? When I put her in the water she was purring like a kitten, then an hour at high throttle through pretty good wave heights and now she won't run at low rpms.
LMAF!!!!
No..the reason I am LMAO is I have never seen a vacuum bubble!!with motor ON spray some soapy water with a small spray bottle behind the carb and the beginning of the reed valve assy and check if with bubbles.
Compression measured in at identical 70psi for both cylinders. Seloc manual says they should be 128psi. Oil added to each cylinder before testing increased psi in one cylinder by 5-10psi and saw no change in the other cylinder. However, introducing oil into spark plug hole was difficult since motor is still in the boat. New spark plugs have carbon coating but no oil which I think means rings are ok(?)...so what is it? Where to start?You must disassemble the carb before soaking. After, blow out all passages.
You may have a sticky float valve.
