Sorry to confound all the experts...the carburetor soaked overnight in OMC cleaning fluid still won't run unless rpms are 4,000+. As a note soaking the o-ring around the high rpm jet screw made it balloon and it had to be replaced - luckily still had the old 8hp carburetor (believe I bought the 9.8hp with electric choke from Paul a couple years back) and salvaged the o-ring from it. However, no improvement. Also swapped the old 8hp carb in and still the same problem. If the choke is held open the motor will run ok at 3,000 or less rpms. Seems there is an air leak somewhere preventing the jets from providing enough fuel at low rpms. I even swapped in the old fuel pump without effect. Adapter for the compression tester should arrive shortly and I'll run that. Any other thoughts? When I put her in the water she was purring like a kitten, then an hour at high throttle through pretty good wave heights and now she won't run at low rpms.
